Fresh 1970 350 Short Block Completely Built
1970 Completely Fresh 350 Small Block Chev SBC short block, Casting #3970010, Date code F170, 4 bolt main, bored .30 over using torque plates, 355 ci, parrallel decked, Arias Forged 11:1 pistons glass beaded & drilled for oiling, Arias full floating light weight wrist pins, completely balanced, blueprinted, magnifluxed block and caps, forged GM index ground & micro-polished crank shaft, polished & shot peened rods, 308/320 Solid lifter Cam .495" lift, True Roller timing gears, + more.
Engine was built in 1980 and never ran or even installed. It was taken apart and "refreshed" in 1997 and never ran or installed again. It has been sitting in a warm garage since. Pretty much everything you can do to an engine has been done to this one. I have all receipts and records. I am located in Vancouver, BC. I really dont know what the market deems its worth, so lets start it at $3000 USD. |
| All times are GMT -7. The time now is 05:50 AM. |
