MSD-6AL ignition box
I am going to use the MSD-8360 distributor with vacuum advance. Should I use the 6Al box or is it overkill/not needed?
My engine is a 1969 427 BBC. Street driven an some autocross. Thanks, Jody |
Yes
The multiple spark function below 3500 rpm really cleans up idle characteristics. Starting and low speed drivability on a carbed car will be better. |
I think you'd be fine with out it. JMO. :P
I would use it not only for the extra spark but also for the rev limiter.
later John |
| All times are GMT -7. The time now is 11:58 PM. |
