-   -   Tremec TKO 600 kit for 67-69 F Body (https://www.lateral-g.net/forums/showthread.php?t=37944)
awake1630 08-10-2012 11:47 PM
Tremec TKO 600 - TKO-600 (Street) 5009 2.87 1.89 1.28 1.00 0.64
Tranny was sent into Hanlon transmission and had over 800 dollars worth of upgrades done to it.
Has brand new carbon lined synchro rings, Machined shift rails to eliminate 2-3 shift lock out.
Brass Tipped shift forks and many other upgrades to help the longevity of the transmission.
Pro 5.0 Shifter.
Comes with lakewood scatter shield and engine protector plate. SFI Approved
Comes with ram billet steel 168 tooth small block internally balanced flywheel for two piece rear main seal motor. SFI approved
Science Friction diaphragm clutch good to handle 550 ft lbs. torque. Full kevlar clutch disc.
X- factor aluminum crossmember for TKO into 67-69 F body.
Speedometer adapter to original cable.
Driveshaft with 1350 U joints. correct length for 67-69 F Body. SFI approved.
Will fit 67-69 F bodys no problem. Bolts right in.
If you add everything up the cost comes out to over 4000.00 dollars. This is a great savings in a kit.
Comes with necessary hardware as well.
3700.00 is a steel for all this.
Call or text John
631-806-3169
awake1630 08-10-2012 11:49 PM
located in bay shore on long island, NY
