Msd Digital 6A PN. 6201 Brand New
2 Attachment(s)
Highlights
Higher output with 530 primary volts and 135mJ of spark energy Efficient components use less current to produce more power Same bolt pattern as the original 6A with a lower profile housing Built-in LED for system checks All wires exit the same side through a locked, sealed connector Operating Specifications Spark Energy: 135-145 mJ per spark Primary Voltage: 520-540 volts Secondary Voltage: 45,000 volts Spark Series Duration: 20° Crankshaft Rotation RPM Range: 15,000 RPM with 14.4 volts Voltage Required: 12-15 volts, 7 volt Start Current Draw: 0.7 amp per 1,000 RPM Size: 8" L x 4" W x 1.825" H Weight: 1.7 lbs Brand New in box Complete harness directions and everything. 160.00 Shipped. call or text John 631-806-3169 |
bump ttt
2 Attachment(s)
ill package this up with a high vibration coil with mounting clamp.
200.00 shipped for everything. |
