MSD wiring
Hi!
I have a MSD 6AL connected to a MSD Boost Timing Master. With the 6AL I can have a theft detterent by connecting the white wire to the ground, but with the BTM the white wire is connected to the orange one from the BTM.... Is there another way to disconnect the ignition to have a theft security ? Is it the good way to connect the violet (from the 6AL) to the ground ? Thanks David |
From the MSD site
THEFT DETERRENT The MSD provides the opportunity to easily install a theft deterrent kill switch (Figure 4). White Wire Trigger When using the WHITE wire to trigger the MSD, install a switch across the magnetic pickup VIOLET wire to ground. When the VIOLET wire is grounded, the vehicle will crank but not start. Magnetic Pickup Trigger When using the mag pickup to trigger the MSD, install a switch to the WHITE wire and the other side to ground. When the WHITE wire is grounded, the vehicle will crank but will not start. |
ok I will do that , thanks...... . |
| All times are GMT -7. The time now is 02:34 AM. |
