17" Budnik Gasser wheels and tires
I have a set of 17x7 and 17x8 Budnik gasser wheels with tires
5 on 4.75 bolt pattern Fronts are 17x7 4" Back space Rears 17x8 4.5" Back Space Tires are Forceum and are like new 205-50-17 245-45-17 $2000 http://i997.photobucket.com/albums/a...ustoms/067.jpg |
You should probably also post the backspace specs... that will help people make a "fit" choice... and also your location.
:cheers: |
Remeasured wheels tonight and If im doing it right the fronts are 17x8 4" backspacing and the rears are 17x9.5 with a 5"
fronts have about a 2.5 " lip and rears have about 3.5 One front wheel has a little bit of curb rash (that could easily be fixed) |
Watch this and see if you are measuring correctly. |
Backspacing is still the same |
on the back of the wheel, located on the mounting surface their is a work order#.
It has a letter and 4-5 numbers. I can tell you everything about the wheels if you give that to me. |
Thats customer service ! :thumbsup: :thumbsup: :thumbsup: |
I4015 I4016 |
Rears 17x8 4.5" Back Space |
| All times are GMT -7. The time now is 12:27 PM. |
