-   Engine (https://www.lateral-g.net/forums/forumdisplay.php?f=37)
-   -   When to upgrade big block internals (https://www.lateral-g.net/forums/showthread.php?t=3824)
bwindy 03-15-2006 04:00 PM
What is your opinion on when to upgrade the crank and rods in a big block Chevrolet (1975 454). In other words how much power can a stock crank handle and the same for rods. Is anyone running a 700 hp engine with a stock rotating assembly with success. I do not want to have an expensive crank and rods just to say that I have them. Thanks
*rayman* 03-15-2006 06:11 PM
i'd also like to know some details on this.
MarkM66 03-16-2006 08:15 AM
I guess it's up to someones opinion, what they want to risk, and what type of rpm's you'll be running.
I was recently reading a "How to Build BB Power", or something like that, and it states a cast crank and 2 bolt block can handle 600 hp. After just recently tearing down a 454 with a cast crank and 2 bolt block, I'd tend to believe that, or more. The journals on the crank are huge, and the main caps are very large to. A two bolt bbc should never be compared to a two bolt sbc, those main caps are puny to say the least.
I'd guess if you added splayed main caps to a 454, and run a forged crank, you could probably through just about anything at it.
You could ask over here, http://speedtalk.com/forum/index.php
There are some real engine guru's over there, :thumbsup: .
