-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   back fire and bogging (https://www.lateral-g.net/forums/showthread.php?t=38317)
morris69 09-11-2012 01:11 PM
I have a 69 camaro with crate ls3, six speed , 411. The issue is im having a back firing problems and sometimes it stutters at different speeds. I had the same problem when I had an ls1 engine doing the same thing. The only thing the same is the exhaust and the fuel system. I'm stomped
morris69 09-12-2012 02:14 PM
Thanks. I'll look into it
MaxHarvard 09-12-2012 02:34 PM
Do you have a fuel pressure gauge? Totally worth having on these new motors.
morris69 09-12-2012 11:22 PM
No I don't have one. But what will that tell me when I get it. Can that diagnose the issue? And how?
camcojb 09-13-2012 12:06 AM
if the fuel pressure is fluctuating it could do the things you describe; also, it's one of the few things you did not change. May not be it, but it's one of the first things you need to verify before you can go much further.
morris69 09-13-2012 05:37 PM
What will the fuel gauge tell me.
camcojb 09-13-2012 07:48 PM
You need a gauge that you can read while driving down the road. The ones that attach directly to the rail are fine for setting static fuel pressure, but you cannot read them going down the road to see if there's an issue.
morris69 09-13-2012 08:10 PM
So I'm running the gauge to c if there is in issue. ( trouble shooting) now if there is one it could be the lines or pump. I'm currently running a ricks stainless tank. Have u guys heard of any issues with those tanks
MaxHarvard 09-17-2012 01:51 PM
I have a ricks tank and it's great.
You're going to have to be a lot more specific if you want better advice.
