-   Lateral-G Sponsor News: Sales, New Product Info (https://www.lateral-g.net/forums/forumdisplay.php?f=43)
-   -   New- GMR AFX Upright Packages (https://www.lateral-g.net/forums/showthread.php?t=38457)
JasonElvisHeard 09-21-2012 04:46 PM
Info and Investment structure coming soon.
Jason
Rick D 09-21-2012 04:56 PM
More info please??? Testing???
JasonElvisHeard 09-21-2012 05:04 PM
I will be posting more info as I get everything up on our website. One thing I can tell you is that the first picture, GMR hub and AFX upright PAIR is going to retail at $1876.99
Jason
coolwelder62 09-21-2012 08:19 PM
Jason
I have bought part's Jason.And they nothing but 1st. Class.:thumbsup: :thumbsup:
Track Junky 09-21-2012 10:23 PM
Do you guys carry a Brake Man caliper/rotor set up to replace Bears C4 applications for first gen camaros with stock spindle? I am currently using Bears Track/Touring set up and am interested in going to Brakeman caliper and rotors up front.
JasonElvisHeard 09-25-2012 08:16 AM
Yes. We have an option for you. I will pm you or please email [email protected]
Even if there is no direct bolt on kit usually we can figure something out.
Jason
Jay@GMR 09-25-2012 03:13 PM
Brake Man Brakes
Hello Gaetano,
First off, thanks for the opportunity to supply you with the info for your potentially new brake setup. I put together some detailed info below for your review. Please let me know if you have any questions.
You would have a few options:
(1) F4 Caliper w/13” x .810 Pro-Cast Rotor …… $2,161.35
*add $300.00 for Brake Man Hub Kit
*add $50.00 for “Black” Ceramic Caliper option
*add $75.00 for slotted faced rotors (not necessary-more aesthetic)
(2) F4 Caliper w/13” x 1.25 Pro-Cast Rotor …… $2,261.35
*Above kits are complete with calipers, pads, plain faced directional rotors, brackets, hardware, and stainless lines.
*Above kits require aftermarket hubs…. yours or optional Brake Man Hubs (as the factory rotor has integral studs and bearings).
* Optional Brake Man Hub Kits come with bearings, seals & wheel studs (hub cost is not included in above kit cost as some customers may already have hubs or want to use other brands)
*If customer prefers to use his current aftermarket hub, center hole register and the depth from the hub face to the spindle mount will be needed at time of order (for hat fitment/offset).
*GMR recommends using NEW Brake Man Hub Kits.
Thanks, Jay
Amituk 09-26-2012 03:16 AM
Coming to a build thread near you soon (see my sig)
I am using a full complement of GMR rolling stock on my car.
Incredible stuff
Track Junky 09-26-2012 03:36 PM
Originally Posted by Jay@GMR (Post 437983)
Hello Gaetano,
Thanks, Jay
Thank you Jay. I am not ready at this time but that will be the direction I am heading. I will contact you when the time comes. :thumbsup:
Jay@GMR 09-26-2012 05:46 PM
No problem, just let me know when the time comes or if you need any other info.
Just FYI, Brake Man use to recommend the BAER hub such as the ones you currently have for A, F, X applications so yours are more than adequit. But they now make their own so just wanted to let you know in case you want the whole Brake Man package!
Thanks again, Jay
