I removed my wipers..looking to cap off stem
anyone use some sort of cap after removing wipers?
This would be a good part for one of the billet companies to produce.
tons avail.. look where the mini truckers go.
http://www.summitracing.com/search/P...r-Post-Covers/ Matt |
Leave your wipers on, that was one of the dumbest things I ever did to my car was shave the wipers.
not looking to shave the wipers..but just remove them for now and place some sort of cap while I have them removed..not looking for some fancy billet ones just a set of rubber or plastic..havent seen anything yet though..
I'm not a 100% sure, but way back when I do believe we used to use these when we removed our wipers to plug the holes on our Camaros. Scuff them and paint to match
SCHWINN BICYCLE HANDLE BAR TAPE END PLUG CAPS STEEL CHROME http://i2.photobucket.com/albums/y3/real3/af7f_1.jpg http://i2.photobucket.com/albums/y3/...inental-01.jpg http://www.ebay.com/itm/SCHWINN-BICY...item2322a6f1f2 |
I have done the same thing. My wipers are in the trunk in case i get caught
in a shower, but usually only drive it in good weather. I sure like not having to look through the wipers when driving as well as the car looks better without them on. I got some plastic black caps at the local ACE hardware store for .99 They fit perfectly and will slip off when needed. I forgot what they are called but should be easy to find. |
| All times are GMT -7. The time now is 01:40 PM. |
