2008 C6 Transmission Diff and Rear Suspension
4 Attachment(s)
Selling complete transmission from 08 c6, tranny flywheel housing and center shaft, also have the complete back end with brakes 3500 for everything, was going to put into my gto but need cash for other suspension mods instead everything is a-1 condition no issues 100% perfect, trans has 22000 miles only on it
The 2008 base Corvette and Z06 have the MM6 gear-ratio transmission. This transmission has a first gear ratio of 2.664 to 1. A ratio of 1.783 to 1 is used for second gear, 1.302 to 1 is used for third gear and 1.000 to 1 is used for fourth gear. Fifth gear has a ratio of 0.741 to 1, and sixth gear has a ratio of 0.502 to 1. The final drive gear ratio for this transmission is 3.420 to 1. This transmission was standard on the 2008 Corvette The Diff is a 3.42 Rob 416 454 9599 |
| All times are GMT -7. The time now is 04:20 PM. |
