new, slightly used, left over parts garage sale
I have some parts left over new and slightly used from my 1st gen camaro builds. Hopefully we can find a good home for this stuff. Time to clear the shelf. Im in Oakland NJ, no power due to Sandy(what a beotch), but manage to get on from the office and family pc's. Shipping cost are the responsibility
of the purchaser. Thanks Rich This crossmember was purchased through Hurst driveline, a TKO-600 install into a first gen camaro, appears to be powder coated. The additional 1/2 inch thick 304 stainless steel spacer I milled to fit the slots and allow you to raise your trans a bit more for a better drive angle. Of course its tunnel height permitting. The spacer is removeable if you dont want it, the piece was used for a couple hundred miles so it looks like new. $100.00 SOLD http://i168.photobucket.com/albums/u...shots078-1.jpg http://i168.photobucket.com/albums/u...neshots080.jpg http://i168.photobucket.com/albums/u...neshots079.jpg Aeromotive 13101 bypass fuel regulator, used for 200 miles and worked great for 58 psi on my ls7. Switched to one of Carls vaporworx tank setups. The regulator retails at summit for 150 and it has 30 bucks in oring to 8AN fittings. Also fabbed up an offset bracket, its removeable.SOLD http://i168.photobucket.com/albums/u...shots069-1.jpg http://i168.photobucket.com/albums/u...shots070-1.jpg Koni rear quadralink shocks(black), 250 miles on them Im up grading to JRI and will supply them with the 250lb DSE springs as well. SOLD. http://i168.photobucket.com/albums/u...neshots063.jpg http://i168.photobucket.com/albums/u...neshots066.jpg Wilwood proportioning brake valve 260-8419, never used brand new, sold http://i168.photobucket.com/albums/u...shots072-1.jpg MBM APV1 proportioning brake valve, never used brand new, SOLD http://i168.photobucket.com/albums/u...shots074-1.jpg Loker e-brake cables and hardware, new , will work for most internal hat design e-brake assy., wilwood etc. SOLD http://i168.photobucket.com/albums/u...neshots067.jpg DSE front coil over springs 450lb 8" length 2.5 dia. never used, just mock up. $60.00 for the pair http://i168.photobucket.com/albums/u...shots068-1.jpg Ac Delco delphi MAF sensor, new, for LS2 and other applications part number 15904068 $80.00 http://i168.photobucket.com/albums/u...shots075-2.jpg Stencil&stripe hockey stick paintable stencil and complete stripe kit in black. The paintable stencil is part number 1051023 and the stick on is 1051021 Both for $100.00 http://i168.photobucket.com/albums/u...shots077-1.jpg |
Sent you PM on ebrake cables and proportioning valve
D |
pm sent
Interested in one of the pro portioning valves and the crossmember. What's still available? I'll send you a PM on specifics.
Parts
I'll take one of teh prop valves idf still available.
PM me your method of payment. Thank you. |
Tranny mount
I have a LS3/T56, do you thing the tranny mount will work?? If so I will take it..
thanks for the reply brother..Thats a great price..
| All times are GMT -7. The time now is 12:47 PM. |
