-   -   6.2 liter LS engine 500rwhp and TR6060 combo (https://www.lateral-g.net/forums/showthread.php?t=39140)
gnx7 11-15-2012 01:37 PM
6 Attachment(s)
I don't want to part out the engine or transmission. They are available either together or separately. This was what was originally going into my '69 Chevelle project; however I'm putting in something with a little more heat :D
6.2 L92 alum Escalade shortblock with approx 10K miles 100% stock
(only difference between LS3 engine is the pistons have valve reliefs in them)
Texas Speed LS3 freshly CnC ported heads with lightweight s/s valves, dual .675" lift springs ($2100)
LS2 timing chain, stock truck oil pump, LS7 lifters, Comp pushrods, LS3 rockers
MLS LS9 head gaskets, ARP head bolts, LS3 intake/inj/fuel rail (no TB), LS3 valley cover
no coil packs, no accessories, no wiring harness/PCM. Truck oil pan included.
With long tube headers this combo should make right around 500rwhp on 91 octane.
$6K FIRM
* your choice of cams: LG Motorsports G6x3 or Comp Cams
235/242 x115 cam
If you want a better oil pump or timing chain I can install them for free if you buy them. Also if you want rod bolts I can install them for free. I can also install any cam you want and credit you $300 for the above cams listed. You buy the new cam and/or rod bolts. I'm simply supplying free labor to assemble it.
* The above shortblock has the LS2/LS3 style rods which are good to around 800rwhp+. Many people are pushing them close to the 1000rwhp mark with stock shortblocks. Meaning if you wanted to... you can spray a healthy dose of nitrous or turbo charge this setup for well beyond 500rwhp. The LS9 head gaskets are great for boost/nitrous applications.
TR6060 6speed from a 2010 Camaro SS with approx 6K miles
Includes an MTI shifter with white cue ball $400+ new. It is in perfect working order and includes the slave cylinder
http://www.mtiracing.com/purchase/ne...camaro-v8.html
Also has an aluminum adapter on the tailshaft to mate up to a 6 bolt common style driveshaft yoke $150+ new
The TR6060 is the transmission pictured at the top of the stack.
$2500 or best reasonable offer
I will do a package deal of $8K. You can't build the motor for cheaper. And I'm throwing in my labor for free.
I ship via Forward Air trucking as I've found they have the best prices.
use the upper blue map to find a terminal near you
http://forwardair.com/locations/falocations.htm
All parts are located in Walnut Creek, CA 94597. Parts will ship out of SFO terminal if not a local pickup. Can deliver within 100 mile radius for a small fee.
sik68 11-15-2012 02:19 PM
PM Sent.
mdprovee 11-15-2012 07:14 PM
Go for it Steven.
Track Junky 11-15-2012 08:56 PM
Originally Posted by sik68 (Post 446578)
PM Sent.
I would love to see this happen. Good luck buddy :thumbsup:
Vince@Meanstreets 11-16-2012 12:28 AM
Me wants that trans
Steven see me for motor mounts and adapter plates!
gnx7 11-16-2012 08:05 AM
The engine is a bit out of Steven's budget.
Vince- You have a PM regarding the TR6060.
Everything is still available.
sik68 11-16-2012 10:17 AM
GLWS Mark! Later if your motor is still around and my willpower isn't, we'll talk again.
gnx7 11-21-2012 07:51 AM
Xmas is right around the corner :thumbsup:
gnx7 11-30-2012 08:29 AM
weekend bump.....
gnx7 12-03-2012 04:08 PM
Now that it is officially December remember to ask Santa on your wishlist for this 500rwhp 6.2 liter aluminum engine and purty TR6060 transmission.
:D
