Small Block Chevy Ram BILLET STEEL Flywheel
2 Attachment(s)
I have a Small block Chevy Billet Steel flywheel for sale.
Basically brand new. Never been cut. SFI approved. Has SFI number on back of flywheel. Will fit any small block chevy internally balanced. Ram Clutches 1501 Billet Steel Flywheel Chevy V8 Balance: 0 Ring Gear: 168 Approx. Weight: 33lbs Bolt Circle: 10.5, 11 B&B, Diaph, 11Long SFI approved number engraved on back. Had it with my TKO. Has not been cut yet. Could use a cut before new installation. Call or text John 631-806-3169 165.00 Shipped |
Is this for 1 piece rear seal or 2 piece ?
Thanks BB |
will work on either one.
As long as the motor is internally balanced. |
Correct me if i'm wrong but isn't there a difference in the center hole (hub diameter), i think 1 piece seal is smaller in diameter
Thank BB |
no there is not because you can take a turbo 350 and mount in up to a later model block no problem and the torque converter snout will fit it no problem.
i had it on a two piece rear main seal motor.
so if you have a two piece then your good. |
I have a one piece rear main, and i'm pretty sure there is a difference. If you had this on a 2 piece i dont think it will work for me.
thanks anyway good luck with the sale BB |
thanks.
Not to butt in...
There is a difference from a one peice RMS flywheel and two peice RMS flywheel The outer hubs are different and the bolt patterns are not the same |
ok thanks for verifying.
Still for sale. SFI APPROVED. |
| All times are GMT -7. The time now is 05:23 AM. |
