-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   ls3 front accessory drive 69 camaro (https://www.lateral-g.net/forums/showthread.php?t=39664)
snappytravis 12-30-2012 08:12 AM
I am thinking about purchasing front accessory drive for 69 camaro, I thought about buying the alternator, ps pump, and brackets off a 2010-12 camaro, I see the alternator mounts low on this setup. The corvette setup mounts the alternator up high on the engine. It will mainly be a street car and I plan on installing a magnuson sc. Just need a little guidance before I pull the trigger the wrong direction, thanks
youthpastor 12-31-2012 06:59 AM
the low mount alternator would work on a '69. I wonder about the supercharger. We have ran a kit from Wegner that works with the supercharger, it is designed around it.-Chris
snappytravis 12-31-2012 05:47 PM
Thanks for the infor, I will keep your shop in mind. I see you sell a lot of good stuff!
Vince@Meanstreets 01-01-2013 05:47 PM
++1 on the wegner drives.
