-   Lateral-G Sponsor News: Sales, New Product Info (https://www.lateral-g.net/forums/forumdisplay.php?f=43)
-   -   GEN II Camaro packages from NVU (https://www.lateral-g.net/forums/showthread.php?t=39822)
marks914 01-10-2013 04:49 AM
http://farm9.staticflickr.com/8492/8...8d0c56f6_z.jpg
GAUGE PACKAGES FOR GENII CAMARO 70-78
New gauge packages for Gen II Camaros takes a new direction in how to install aftermarket gauges into the dash. These packages replace the OE gauge carrier fitting behind the original dash bezel for a factory-installed look, no cutting or modifications required. Simply remove factory bezel and c arrier, bolt new assembly in place, adjust as needed and wire it up. Panel is designed with adjustability to adapt to variations in different build tolerances. Kits also incorporate our exclusive indicator panel with turn signals, hi beam, check engine, brake and warning lamps.
Below Left: With the NVU Performance kit in place behind the factory bezel, looks like it was meant to be there. Below Right: Detail of the indicator panel visible through the factory PRNDL window.
http://farm9.staticflickr.com/8496/8...028b575a_z.jpg
INCLUDED IN EACH KIT:
Mounting bracket
Center mount indicator
Speedometer
Tachometer
Water temperature gauge
Oil pressure gauge
Voltmeter
Fuel level gauge 0-90 match
Temperature sender
Pressure sender
Sender bushings
GM speed sender included with performance kits
More images:
01670-01 PERFORMANCE GEN II CAMARO KIT 4-3/8" S/T BLK
Bold performance graphics, black dial, 4-3/8 speedo and tach with 2-1/16” minor gauges. Black dial with white print perimeter incandescent lighting.
http://farm9.staticflickr.com/8203/8...b78e3333_z.jpg
http://farm9.staticflickr.com/8060/8...c4384826_z.jpg
01670-03 PERFORMANCE GEN II CAMARO KIT 4-3/8" S/T WHT
Bold performance graphics, black dial, 4-3/8 speedo and tach with 2-1/16” minor gauges. White dial with black print, perimeter incandescent lighting.
http://farm9.staticflickr.com/8477/8...45c1b1fb_z.jpg
http://farm9.staticflickr.com/8350/8...b318ec06_z.jpg
69670-01 69 SERIES 6 GA KIT GEN II CAMARO
Musclecar graphics, backlit mint green on black background. Full sweep programmable minor gauges with warning outputs. 3-3/8” 160 MPH speedo, 10,000 RPM tachometer.
http://farm9.staticflickr.com/8210/8...47d35c70_z.jpg
[url=http://www.flickr.com/photos/90719091@N02/8265855105/][img]htt
