69 Camaro gauge packages from NVU
http://farm9.staticflickr.com/8346/8...0bdef037_z.jpg
New gauge kits and mounting solutions for 69 Camaro from NVU Our exclusive molded mounting kit installs any of our 4-3/8" gauges into the factory 69 Camaro dash openings. The design makes the installation look like it came from the factory. Click the pics for a closer look. Molded and CNC cut pockets that fit into the stock dash for a factory installed look. Install ant New Vintage 4-3/8" gauges. You can use a 2 gauge set, or our 4-3/8" speedo and tach, mounting the minor gauges in the console, its up to you. PART NO 88690-09 69 CAMARO MOUNTING POD KIT Below Left: Kit includes Left and Right mounting pods, brackets and detailed instructions. Requires trimming clearance on the back of the dash not visible when installed. Below Right: Gauges fit tightly in bezel and is compressed against the factory dash opening for a great fit. http://farm9.staticflickr.com/8207/8...1c15a547_z.jpg Below: Just a few examples of how you can set up the dash to fit the theme of your car. Select the gauge style and layout that suits your build. 3-in-1 gauge kits have all the functions you need right in front of you in a 2-gauge kit. Speedo, tach, fuel (0-90 GM match) temperature, oil pressure and voltage. All 3-1 kits include turn signals, high beam and warning lamps, integrated right into the gauge. For a more traditional setup, run a 4-3/8” speedo and tach with minor gauges in the console. Its up to you. Shown below: 69 series 3-1 gauge kit 69253-01. Musclecar inspired late 60s, early 70s mint green backlit graphics on a black background. Perfect for a resto-mod or pro-touring build. http://farm9.staticflickr.com/8199/8...499816b7_z.jpg http://farm9.staticflickr.com/8069/8...8b316a6251.jpg Performance style: Bold modern graphics have a performance look without going overboard. Perimeter lit dials are easy to read day or night. A great choice for a more modern, performance inspired pro-touring look. http://farm9.staticflickr.com/8486/8...f3ac7c814e.jpg http://farm9.staticflickr.com/8199/8...6253226848.jpg http://farm9.staticflickr.com/8065/8...2e149742b8.jpg http://farm9.staticflickr.com/8063/8...ce330afc8d.jpg |
Nvu, Powerblock,69 Camaro Dash Inserts
POWERBLOCK TV MUSCLECAR EPISODE 12, BUILT TO FIT NVU'S 69 SERIES GAUGES ARE A QUICK AND EASY UPGRADE FOR THE STOCK 69 CAMARO DASH.. ALL ITEMS IN STOCK
http://www.summitracing.com/parts/nvu-69253-01 http://www.summitracing.com/parts/nvu-88690-09 www.newvintageusa.com www.theshopllc.com http://i281.photobucket.com/albums/k...VEPISODE12.jpg |
I would think those will be popular Mark. :thumbsup:
| All times are GMT -7. The time now is 05:30 AM. |
