-   Paint and Body (https://www.lateral-g.net/forums/forumdisplay.php?f=52)
-   -   CAC mini tubs Gen II Camaro (https://www.lateral-g.net/forums/showthread.php?t=39845)
NorCal72 01-11-2013 09:07 AM
Is there any difference between Chassis Works and the DSE tubs for the Gen II Camaro application?
I was recently told I would need to modify the frame rails to fit my 335's. I have been searching and havent found a detailed thread on a Gen II install. I have followed several threads with mini tubs and never saw anything about a frame rail mod, is it needed? Kind of on a time crunch, I appreciate any help. Thanks Kevin
32deucecoupe 01-11-2013 07:22 PM
here is a link to first gen mini-tub, not sure about second gen but this was the most complete thread I have ever come across.
http://www.pro-touring.com/showthrea...a-68-69-Camaro
here is another that is for a 70-81 camaro from carcraft..It does look like cutting will be required..
http://www.carcraft.com/howto/ccrp_0...t/viewall.html
KPC67 01-12-2013 09:34 AM
The car craft link is has some pretty good pictures.
for the tubs themselves I don't think you have to cut the frame, the frame only needs to be cut along the bottom for the leaf spring to be moved inward.
32deucecoupe 01-12-2013 04:13 PM
After looking at it again I believe you are right, be nice if first Gens were the same..
NorCal72 01-12-2013 04:43 PM
I should have added I wont be useing leaf's, I would be going with a g link setup. Thanks for the input guys.
