-   Interior and Electrical (https://www.lateral-g.net/forums/forumdisplay.php?f=40)
-   -   Heavy duty connector for starter? (https://www.lateral-g.net/forums/showthread.php?t=40697)
Ripped 03-17-2013 06:11 PM
One of the problems I have is getting the starter and soleniod cables onto the starter, after the engine is installed.
I can barely get my hands and a wrench in there.
I was thinking if there is a realiable heavy gauge connector, that I can use, between the starter and the cable to the battery, it would be way easier.
Any thoughts or suggestions?
canrc 03-17-2013 08:25 PM
Do you mean a bulkhead connector like this one?
http://www.summitracing.com/parts/mor-74145/overview/
or the actual lugs that are attached to the end of the battery cable? The other thing I found very helpful was going with a welding cable instead of the standard battery due to its flexibility.
smhigh 03-17-2013 10:11 PM
M.a.d.
http://www.madelectrical.com/catalog/st-1.shtml
This in my opinion is the best way to go.....Ford Solenoid
Works on my Nova and Camaro.
