-   -   MSD High Vibration Blaster Coil 8222 (https://www.lateral-g.net/forums/showthread.php?t=40703)
awake1630 03-18-2013 08:07 PM
2 Attachment(s)
ike new MSD high vibration blaster coil with bracket.
Better then regular blaster coil because it is encased in epoxy and not oil filled.
Can be mounted any way.
COIL Specs:
Turns ratio: 100:1
Primary resistance: .7 OHMs
Secondary resistance: 4.5K OHMs
Inductance: 8 mH
Maximum voltage: 45,000 Volts (Tested with 6AL Ignition)
Peak current: 140 mA
Spark duration: 350 uS
comes with mounting bracket.
Asking 35.00 shipped
only used for a month
call or text John
631-806-3169
