-   -   LS Engine Coil Relocation Idea, Will it work? (https://www.lateral-g.net/forums/showthread.php?t=41841)
Iamtheonlyreal1 06-13-2013 02:34 PM
I am really wanting to hide the coil packs on my build, and thought about relocating them to the inner firewall, but I would like to find a closer place to do it.. I have this little pocket in my crossmember kit, along with a unibody frame rail relief for the oem upper a-frame, so it makes a nice little pocket.. I understand that there would be potential water during rains and ect, but these coils are pretty well water proof from what I understand, with the exception of the actual power/signal plug and plug wire, which I am sure can be dealt with..
There should be enough fresh air, along with actual header air gap clearance to run fairly cool, so I am not sure if that would be a major factor at all. I am thinking they would actually run cooler than being trapped in the engine bay air space, while mounted to the valve covers.. Just wondering what some of your thoughts might be, and if anyone has mounted the coils more in the open elements?
http://i290.photobucket.com/albums/l...ps566cfb05.jpg
http://i290.photobucket.com/albums/l...pseb62c7fc.jpg
http://i290.photobucket.com/albums/l...ps7988d9be.jpg
Here are some earlier Header Clearance pics of the same area.. I was thinking just a basic rubber style dust flap might do the trick?
http://i290.photobucket.com/albums/l...zon/010-15.jpg
http://i290.photobucket.com/albums/l...zon/013-11.jpg
http://i290.photobucket.com/albums/l...ps32b5df9f.jpg
96z28ss 06-13-2013 06:11 PM
How much clearance do you have between the firewall and the back of the heads.
If you have enough room then you should get a set of these.
http://www.automotivedesigneng.com/p...coil_pack.html
more pics here
https://www.facebook.com/media/set/?...9836708&type=3
Iamtheonlyreal1 06-13-2013 06:38 PM
Those are pretty cool, but I dont really have that much room, but it does give me an idea.. I have way more room at the back of the block/bell housing area, so I might be able to mount them more center in the rear.
boostin05blacks 06-13-2013 07:11 PM
I have some pictures in my build thread of where I placed mine...
Starting on page 18...
https://lateral-g.net/forums/show...hlight=lsx+454
Iamtheonlyreal1 06-13-2013 07:21 PM
It appears that you would also recieve some road moisture, have you driven the car yet, or in normal elements?
