-   Interior and Electrical (https://www.lateral-g.net/forums/forumdisplay.php?f=40)
-   -   battery cables (https://www.lateral-g.net/forums/showthread.php?t=42028)
snappytravis 06-26-2013 01:08 PM
battery cables
I am just curious why some run only the positive cable to the front and the the ground to the frame when moving battery to the trunk. I have noticed others run the negative all the way to the front and then through the floor with the positive cable. Whats up with that?
XLexusTech 06-26-2013 02:54 PM
For me it makes sens to have a real direct ground form the ECU to the Batt Negative.. It may be overkill but I like having a point to pick up the grounds up near the ECU which for me is under the dash.
RdHuggr68 06-26-2013 04:43 PM
I just relocated my battery to the trunk of my 68 Camaro and ran the neg cable #1 gauge to the trunk floor next to the battery. I then ran a 2/0 from the bellhousing to the body lower passenger firewall, and a #4 gauge from the radiator support to the subframe. Everything works great you just have to make sure you clean your grounding points down to bare metal before attaching grounds.
Kevin
roysbb 12-15-2013 07:52 AM
return path when cranking
There is HUGE spike of current that flows from the battery to the starter/block when cranking. Even on the negative side.
If you only use a positive cable from the trunk to the starter and rely on the chassis to carry the return current you add resistance at every junction.
Essentially this return path will perform like a much smaller cable.
Every junction is prone to corrosion and arcing and is not as reliable as a cable connection with its only junctions being at the cable ends (the battery terminal and a large lug to ground near the starter, usually on the block).
Even if you tie the battery directly to the subframe and then from the subframe back to the block - you have doubled the number of junctions in that path. Over time every one of them becomes a potential resistance to current. Resistance generates heat and can melt connections.
This is DC current and will flow through the core (rather than the surface as high frequency signals will). Since this is the case, high strand count is not necessary. High strand count cable is much more prone to corrosion and will fail sooner than a cable using larger sized conductors. The trade-off is flexibility. Seal both ends where the insulation is cut with liquid electrical tape so that corrosion will not start under the insulation.
Possible alternative sources are welding cable, and even high-end jumper cables. I spent almost $80 for a really nice set of jumper cables for one project, they were plenty long and very flexible.
These jumper cables even had the two cables connected by the insulating shield which made for an elegant looking solution.
Hope this helps, Roy
