-   -   Johnny joints (https://www.lateral-g.net/forums/showthread.php?t=42174)
no go nova 07-06-2013 08:06 AM
Johnny joints
Has anyone you johnny joints in place of heim joints for front upper and lower control arms?
http://www.currieenterprises.com/ces...nnyjoints.aspx
MarkBsae 07-07-2013 07:52 AM
Those are designed for movement that includes axial misalignment and in a typical A arm your pivot axis travels through the two inner connections. It seems those joints are designed for considerably moe axial misalignment than your typical A arm will encounter. Plus they are rather big.
my .02
no go nova 07-07-2013 10:30 AM
They make them smaller. What I like is being able to grease them, and a better ride on the street.
ironworks 07-07-2013 09:50 PM
Not quite sure how they are going to ride any smoother then rubber press in bushings.
79 Camaro 07-08-2013 01:43 PM
I was wondering the same thing. They could give you more articulation and be much quieter than the typical "groaning" poly bushing I have on a Heidt rear four link. Even after greasing it doen't take long till they are noisy again. I thought I saw Art Moorison is offering them on their four links now.
Sieg 07-08-2013 02:53 PM
Page 23 of their catalog show the rod end options with features and benefits. :thumbsup:
Apparently Strange Engineering is the original designer of the Johnny Joint.
ironworks 07-09-2013 04:50 PM
In a 4 link application they work great. The OP talked about using them on his upper control arms in place of his rod ends.
