Camaro 69 rubber windshield molding
Does anybody know what kind of rubber molding can I use on a 69 camaro rear windshield? My body work is off 1/4 in. Metal molding is looking
like crap. |
:confused59: You might want to post a few pictures of what the exact problem is, chances are some one has run across a solution. I don't believe that there is an off the shelf solution as to what you are referring to. It may require you to pull the back glass out and space it up or down depending on what you are trying to fix.
| All times are GMT -7. The time now is 05:30 AM. |
