-   -   FS: Bunch of parts for Small Block (https://www.lateral-g.net/forums/showthread.php?t=4223)
Nutsy 04-18-2006 10:38 AM
I have a bunch of parts for a Small Block engine for sale. Everything is new unless noted as "used". Everything has been stored in a dry place for some time now:
For all pictures please visit: Part Pics
Isky Springs - $85.00:
http://store.summitracing.com/partde...5&autoview=sku
Isky Chromoly Retainers - $50.00: http://www.iskycams.com/pdfcatalog/2004-05/page33.pdf They are the 507-st
Isky Chromoly Valve Locks - $45.00: http://store.summitracing.com/defaul...5&autoview=sku
Isky Solid Lifters - $85.00: http://store.summitracing.com/defaul...h.asp&N=400418
Isky Valve Seals Part Number IVS-11/32 - $20.00: http://www.iskycams.com/pdfcatalog/2004-05/page15.pdf
Manley Valve Guides 3/8" Wide Part Number 42147 Small Block Chevy Plastic Guide Plates on Center Stud Holes Stock Location Slots 3/8" Wide - $20.00
Isky Cam Bolts & Lock Part Number ISK-200-LP - $5.00
Milodon Timing Cover Bolts Bolts Timing Cover Small Block Chevy 1/4"-20 X 1/2" 10 Pack Part Number MIL-85260 - $5.00
Used Slightly Holley Fuel Pressure Gauge Gauge, Fuel Pressure, 0-15 psi, 1 1/2 in., Analog, Mechanical Part Number HLY-26-500 - $20.00
Custom 1.5" Open Bore Carb Spacer CNC Billet Aluminum - $80.00
Used Moroso Bluemax Spark Plug Wire Set - $15.00
Chrome Alternator Brackets - $10.00 each:
http://www.momentummotor.com/Trevor/...torBracket.jpg
http://www.momentummotor.com/Trevor/...torBrakets.jpg
Chrome Alternator Pulley and Fan - $25.00
http://www.momentummotor.com/Trevor/...lleyAndFan.jpg
Chrome crank pulley - $10.00
ARP Main stud set for a 4 bolt main small block w/ Windage Part Number ARP-234-5601 - $65.00
Erson Chrome Aircleaner Part Number E981101 - $25.00
Moroso Lifter Valley Oil Baffle Part Number 710-25050 - $15.00
Moroso 14x3" Air Filter Part Number 97080 - $5.00
Moroso Racing Crank Pulley Part Number 6410 - $25.00
http://www.momentummotor.com/Trevor/...ank-Pulley.jpg
Moroso Solid Motor Mounts - $15.00
Moroso Spark Plug Index Washers - $10.00
Chrome Water Pump Pulley - $15.00
http://www.momentummotor.com/Trevor/...umpPulley1.jpg
