-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   Lq install question second gen f body (https://www.lateral-g.net/forums/showthread.php?t=42931)
FIREFIGHTER273 09-06-2013 03:55 PM
Hello folks, what radiator should I be looking for doing an install into a second gen trans am" or will the factory 403 radiator work? Thanks.
Vince@Meanstreets 09-06-2013 10:30 PM
If you can find the hoses to fit it should work just fine. We run LS compatible AFCO radiators and it takes standard hoses for 99-02 Camaro.
WSSix 09-07-2013 08:54 PM
Yes, the 403 radiator will work if it's in good condition. Mine was shot so I got a DeWitts radiator for it. It's the same dimensions as a C3 Corvette big block radiator. You just have to ask them to put straight LS size ports plus the steam port on there. Basically, no big deal really.
Oh, my car came with the HD radiator. That was the same size as the BB vette radiator. I'm not sure on the dimensions for a standard 403 radiator. I'm sure the standard radiator will work though for your LS. Just look at the size of a 4th gen Fbody radiator.
