Change in direction Parts Sale! Strange, Moser, Wilwood, Hotchkis
My project has changed direction. I have listed a vast assortment of parts. All parts were purchased for a 1979 Z/28 Camaro. All parts listed have a related mfg. part number please make sure they fit your application. All parts are located in Macomb Michigan and are plus freight to your destination of choice. Thank you. ALL PARTS ARE BRAND NEW IN BOXES. NEVER EVEN FIT UP!!!! I'm open to reasonable offers also.
1. MOSER 9” Axle housing with 35 spline gun drilled & lightened axles with tapered bearings. Factory width and mounting. MSR-CUSTOM $1050.00 PENDING 2. STRANGE ENG. Aluminum Pro case with 35 spline S-Track and Billet Yoke. 3.89:1 ratio. STR-PRF180, STR-OPRF10,STROPRF07. $1800.00 PENDING 3. WILWOOD Six Piston Front Brake kit Red calipers and black drilled rotors 12.88” WIL-140-12280-DR $950.00 PENDING ** I also have a set of refurbished '79 spindles to use with brake kit $90.00 PENDING 4. WILLWOOD four piston rear kit with E/brake for staggered shocks 12.19” WIL-140-9560-DR $750.00 PENDING 5. WILLWOOD Font and rear Flexline kit WIL-220-10509 &WIL-220-7056 $90.00 PENDING 6. DETROIT SPEED REAR AXLE FLEXLINE DSR-050201 $25.00 7. HOTCHKIS TVS STAGE 1 KIT HSS-80017 SOLD 8. HOTCHKIS UPPER CONTROL ARM HSS-1106 SOLD 9. HOTCHKIS LOWER CONTROL ARM HSS-1108 SOLD 10. HOTCHKIS SUB-FRAME CONNECTORS HSS-4013 SOLD 11. HOTCHKIS CHASSIE MAX HANDLE BARS HSS-20103 SOLD 12. HOTCHKIS FRONT AND REAR BILLET SWAY BAR BRACKETS HSS-23290875,HSS-23341375 $175.00 13. HOTCHKIS FOX TUNED SHOCK SET HSS-79020004 SOLD 14. GLOBEL WEST SUBFRAME BUSHINGS GLS-800 $90.00 |
I will take these, if you will ship them for $90. Zip is 30132. I will PayPal immediately. |
Will the wilwood rear kit work with a ten bolt? Which caliper is it? Slotted or drilled rotors? Caliper color?
I assume since you skipped over my post, that you don't want to sell.
No you didn't, not on either site. Its all good.
| All times are GMT -7. The time now is 05:49 PM. |
