90 degree Quick Disconnect Fitting
1 Attachment(s)
I have been looking and I cannot find any steel 90 degree quick disconnect fittings like the stock style in the picture. I can get the plastic ones but want the steel. I need (2) 3/8 and (1) 5/16 fitting. If anyone has these or knows where I can get them please let me know. Thanks in advance.
Hey Guy,
I haven't had any luck on those but what I do is buy the GM service part, cut it at the hard line section. Then use an Earls compression fitting to -6 fitting to connect to the system. Had no luck with the 5/16" hose or fitting. I'd love to find a good hose crimper to make these using the GM service hose. GM Part # 92228251 Camaro LS3 Engine Compartment Fuel Line, sometimes you find them on ebay cheap. There are 2 90's on this part. |
I just sent the pic to a local friend to see if he can fab them. Any more specifics regarding what would make the part ideal?
he was hoping to avoid the price.
(1) 5/16" hose with 90 degree and a straight fitting with about 12" of hose (2) 3/8" hose with 90 degree and a straight fitting with about 12" of hose (3) 3/8" hose with 90 degree and a straight fitting with about 30" of hose If he can do it please let me know and I will get a price and give him exact measurements. Thank you for checking |
| All times are GMT -7. The time now is 12:29 AM. |
