LS Parts, BMW Seats ""Reduced Prices""
1 Attachment(s)
Item Location (City/State): Las Vegas, NV
Price: $1234 Description: Used Parts Cleaning out the garage and have many LS parts for sale. Located in Las Vegas, NV LS1 motor out of a 2000 corvette. It appears to be low mileage. Comes just as pictured with intake (not an LS6). Has a DBW throttle body. No injectors or fuel rails. Heads are 853s $1600 Sold LS3/L92/L99 823 casting Heads. These are off a 2011 camaro with 13k on them and come with stock valves and valve springs. These are not the sodium filled valves. $600 Sold LS3 821 Casting Heads. These are bare castings, no valves or springs included. Came off of a 2010 Corvette with 30k on it. $325 Sold LS1 853 Casting Heads. Come with stock valves and valve springs. $100 LS Rocker Stands. Will fit all LS based engines except for the LS3/LS7 type heads. $25 for the pair. L92 Truck intake. Requires rectangle port heads and a 4 bolt Throttle body. No fuel injectors or rails included. $50 Sold LS1 5.7L Pistons and rods. I only have 7 pistons and 7 rods. $75 LS1 F-Body water pump. $50 Sold LS1 F-Body Balancer. $40 LS1/LS6/LS2 Valve covers with bolts. $50 LS2 Oil Pump. This should fit any LS style motor. I pulled this out of an LS2 that was in a CTSV with 73k on it. $30 PCM 896 Red/Blue $50 Sold LS Pushrods Stock Length 7.4 These are stock. I have 2 sets. $20 per set. LS Chromoly Pushrods 7.550 .080 by Texas Speed $80 LS1 Valley Cover. $30 LS1 Front Cover. $30 Sold LS1 Rear Cover. $30 Cloyes timing set. this a double roller set for a gen III motor with a 3 bolt cam. It is brand new however the machine shop lost the crank sprocket so all i have is the chain and the cam sprocket. Part #9-3159 $30 LS1/2/6 16 Stock Rockers. The trunions have been removed and are ready for the comp trunion upgrade. $45 LS 3 bolt DBW throttle body with sensors. part # 25317951 $60 Sold MAF stock 78mm 3 pin plug. $40 LS1 Steam tube. may have to be messaged a little back into shape. $25 Weiand Team G single plane Small Block intake. $60 C5/C6 Front and Rear Brake calipers and Abutment brackets. $400 Sold BMW 3 series seats. All power and easy to hook up 2 wire install. $300 Thanks Jerry 712-253-7583 |
Parts list updated.
Price drop. Prices have been updated.
Do those brakets allow the calipers to bolt up to 69 camaro spindles?
They do if you have ATS spindles. If you don’t I believe you would have to buy the brackets from Kore3.http://www.kore3.com/proddetail.php?prod=10083-02
To the top
To The Top
LS1 is Sold!
PM sent about LS-3 heads
All PMs replied to. Still have a lot of parts for sale.
| All times are GMT -7. The time now is 09:10 AM. |
