-   -   anyone with a wayne due subframe (https://www.lateral-g.net/forums/showthread.php?t=44411)
lubeguy 12-24-2013 08:12 AM
looking for someone with a wayne due subframe putting an ls1 in it and the clearance is an issue i seen pictures and it looks like the later version might be higher to the center of the motor mount from the crossmember if someone has an ls in that subframe i need a measurement from the flat of the crossmember to the center of the motormount bolt thanks
Ron in SoCal 12-24-2013 08:43 AM
Man for a second that was tough, but I ran it through my Snopp Dogg translator and I think I know what you mean:
http://www.gizoogle.net/textilizer.php
lookin fo' one of mah thugs wit a wayne due subframe puttin a ls1 up in it n' tha clearizzle be a issue i peeped pictures n' it be lookin like tha later version might be higher ta tha center of tha motor mount from tha crossmember if one of mah thugs has a ls up in dat subframe i need a measurement from tha flat of tha crossmember ta tha center of tha motormount bolt props
Sorry man, can't help. :D
Merry Christmas though! :cheers:
GregWeld 12-24-2013 09:01 AM
#1 -- If you haven't bought the Wayne Due sub yet -- there's FAR FAR better subs out there.
SpeedTech
Art Morrison -- Wayne Due "version"
DSE
ChassisWorks
TCI
Our own Mister "CoolWelder62"
130fe 12-24-2013 10:25 AM
Contact Z06vette (Scott), he has done this conversion in his 69.
lubeguy 12-24-2013 11:34 AM
Thanks already have everything just going to raise the mounts how far is the question
redefined 12-24-2013 02:41 PM
SpeedTech
DSE
ChassisWorks
TCI
I never see Heidts listed when people discuss this, is there a reason?
GregWeld 12-24-2013 03:03 PM
My "GUESS" is just by looking at it -- it's based on Mustang II suspension settings -- the others are Corvette C-5 or C-6
I'm not trying to make the comparison so am not going to go check out all the various manufacturers to figure out who's making what... so this is just an unedumakated opinion that may not be valid at all.
Z06vette 12-24-2013 03:44 PM
wayne due
My wayne due is an older version I believe. I bought it used quite a while ago, and it was originally set up for a big block. I had no issues with depth. I acutally cut the frame stands and shortened them to get the motor and trans down to 3 degrees from the 5 it was sitting at. I also had trouble getting the motor mounts lined up, as the stands were too close together and would bottom in the mounts, not allowing it to set down far enough to line the bolt holes up. I addressed this at same time that the mounts were shortened. Have you test fit the motor? If so post up some pics & lets see where youre running into issues. I'm using the stock F-body pan, if that helps you.
lubeguy 12-25-2013 11:19 AM
i have a mast and a stock f body pan neither will work there hitting the rack the engine has to move up the measurement from the crossmember to the center is 6" thanks for the help
71RS/SS396 12-25-2013 11:44 AM
X2
I have no idea what he's asking
