-   -   2014 OLC Garage Sale - Lots of parts (https://www.lateral-g.net/forums/showthread.php?t=44558)
James OLC 01-05-2014 10:30 PM
Item Location (City/State): Central California
Price: as listed below plus shipping
Description:
Updated March 19th, 2014
I'll add pictures and a few more parts over the next day or two as I get info loaded up... More pictures and information is also available on my Facebook page at https://www.facebook.com/OLCGarageSale
1967 Camaro custom modified front subframe (will fit 1967 - 1969 F-body and Nova). Fully seam welded, converted for coil overs using SpeedTech ATS Chicane kit, SpeedTech high clearance upper and lower control arms, ATS AFX billed spindles with SKF hubs and ARP wheel studs. Custom modified centerlink, 2nd gen outer tie rod ends, custom built steering arms, custom valved RideTech triple adjustable shocks with Hyperco coil springs, Baer 14" rotors, Lee Engineering 670 Steering box, ATS LS engine mounts. Also includes all stainless steel brake lines. First Chicane subframe built by ATS and featured in the 2008 SEMA Show. Subframe was powder coated (titanium) and then sanded and painted.
and
ATS Tri-Y stainless steel headers and 3" Magnaflow exhaust system. Custom modifications to the headers to address low hanging collectors common with these rare pieces. Fit all LS engines including LS7, can include new ls7 header gaskets and bolts. Exhaust system includes Magnaflow true-x crossover and stainless mufflers. Ridicules amount of work done on exhaust (welds ground smooth, etc). Entire system - headers, exhaust, and mufflers - Jet Hot coated (titanium finish).
This is a bolt in and go solution to get your LS project up and running fast immediately.
I have $8500 in parts/labor and countless hours/$s in tuning on the subframe and $4500 in the exhaust - asking $8000 plus shipping (prefer local pickup) - will not separate
LS7 Intake Manifold and stock Fuel Rail. Like new but with one dyno pull. Does not include injectors or TB. Asking $250 plus shipping
https://scontent-a-lax.xx.fbcdn.net/...11595634_n.jpg
LS7 fuel rail (stock - no injectors, no intake) - dyno time only - $80 plus shipping
https://scontent-b-lax.xx.fbcdn.net/...43512636_n.jpg
FAST Fuel Rails and Fuel Rail Crossover Kit (PN 146027 and 54028) Both are new and unused. Fuel Rails still in sealed box, crossover lines were opened but not used. Don't want to separate, asking $240 plus shipping for both
https://scontent-a-lax.xx.fbcdn.net/...09961870_n.jpg
McLeod 8710-10 SFI Approved bell housing - sold
Powermaster LS "mini" Starter - PN 9509 - sold
Canton 22-480 Remote Oil Thermostat - includes -12AN O-ring fittings as shown. Used but in excellent working order. Includes mounting bracket. $120 plus shipping.
https://scontent-b-lax.xx.fbcdn.net/...90393278_n.jpg
Willans Club Silverstone 5-point cam-lock harness. Blue, certified through 2013 (sub belt through 2014) – new in the original packaging, never used. Retail is $350, asking $200 plus shipping
https://scontent-a-lax.xx.fbcdn.net/...12276083_n.jpg
Anvil carbon fiber hood - PN 010043: Satin 67-69 100% Carbon Fiber Bare Hood, Used - body worked and painted by Best of Show, Includes 1 vent with screen - needs 1 vent with screen - Ring Brothers Hood Pins available as well for $150 (Set up for hood pins but can use stock latch as well)- $1100 plus shipping
https://scontent-a-lax.xx.fbcdn.net/...71068589_n.jpg
Setrab Oil cooler - P/N 50-925-7612 - used. 16" x 7.6" x 1.5", plumbed for -12AN (fittings included) - perfect working order. Asking $200 plus shipping.
https://scontent-a-lax.xx.fbcdn.net/...37914716_n.jpg
GM LS7 Oil Pan Gasket - PN 12612351 (qty 1) - new. Asking $50 plus shipping
https://scontent-a-lax.xx.fbcdn.net/...73884447_n.jpg
Chase Cam System #1 - $450
PDR100 recorder
600 line bullet camera
Standard Camera mount
5' Mini DIN camera extension cable
Remote AA Battery pack
http://www.onelapcamaro.com/sale2012...cam%20PDR2.jpg
Chase Cam System #2 - $500
PDR100 recorder with G-force meter (auto start)
Suction cup mount mount
Standard camera mount
Cigarette lighter power adapter
PIM10 Power Isolation Module
http://www.onelapcamaro.com/sale2012...cam%20PDR1.jpg
Buy both systems and I'll through in a dual recorder mounting kit ($89) and a case.
McLeod RST Cutch - $250 - Part Number 6912-07 - aka "Smokey" - SOLD
McLeod RST replacement clutch disks (front and rear disks) - $240 (pair) - SOLD
Kinsler Spec Bosch 10211 Fuel Pump – new in the box (was an OLOA spare) – Retail was $360, asking $300 obo plus shipping.
http://www.onelapcamaro.com/sale2012...mp%2010211.jpg
Track Rat Engine - - SOLD
Wheels (will update backspacing ASAP):
HRE Comp 93 (C93) Wheels 19 x 10.5" - Satin Black Powdercoat Center, Brushed and Clear coated outer hoop and satin black powerdcoated inner; Step lip. $1,900 (pair) plus shipping
HRE Comp 93 (C93) Wheels 18 x 9.0" - Satin Black Powdercoat Center, Brushed and Clear coated outer hoop and satin black powerdcoated inner; Step lip. Offset is +36 with an 8.0" inner and 1" outer. $1,900 (pair) plus shipping (available with NEW Michelin Super Sport 275/35-18 tires, excellent condition for an additional $400)
HRE Comp 93 (C93) Wheels 19 x 12.0" - Satin Black Powdercoat Center, Brushed and Clear coated outer hoop and satin black powerdcoated inner; Step lip. Offset is -3.9 with a 7.0" inner and a 5.0" outer. $1,900 (pair) plus shipping (available with Michelin Super Sport 305/30-19 tires, excellent condition for an additional $300)
Tires:
Michelin Pilot Super Sport tires 2 x 325/30ZR19 - $750 (pair)
New - never mounted - perfect condition
Marked for 2012OLOA
Michelin Pilot Super Sport tires 2 x 305/30ZR19 - $600 (pair)
Used one track day - minimal tread wear - perfect condition
Marked for 2013OLOA
Michelin Pilot Super Sport tire 1 x 305/30ZR19 - $300 (each)
Marked for 2013OLOA
Michelin Pilot Super Sport tires 1 x 325/30ZR19 - $375
New - never mounted - perfect condition (located in IL)
Marked for 2012OLOA
Michelin Pilot Super Sport tires 1 x 275/35ZR18 - $200
Marked for 2012OLOA
... everything is first PM or Email, first served. Prices do not include shipping
Parts are in Central California (unless otherwise indicated) so delivery within California might be possible depending on timing and location.
Thanks for looking!
califconstruct 01-06-2014 08:28 AM
HRE wheels.
P.M. Sent.
ADiCarlo 01-06-2014 10:24 AM
PM Sent last night.
James OLC 01-06-2014 11:00 PM
All PMs replied to.
Since I can only add so many pics to a single post, here are some of the HRE wheels:
https://scontent-a-lax.xx.fbcdn.net/...47120461_n.jpg
https://scontent-a-lax.xx.fbcdn.net/...26681541_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.n...26230474_n.jpg
https://scontent-a-lax.xx.fbcdn.net/...07958268_n.jpg
https://scontent-a-lax.xx.fbcdn.net/...03267590_n.jpg
https://scontent-a-lax.xx.fbcdn.net/...05787157_n.jpg
https://scontent-b-lax.xx.fbcdn.net/...25882341_n.jpg
https://scontent-b-lax.xx.fbcdn.net/...25202310_n.jpg
https://scontent-b-lax.xx.fbcdn.net/...64270843_n.jpg
Cheers and thanks again for looking
dcrider69 03-05-2014 08:11 PM
Is the complete clutch from the other post still available?
Thebigtomato 03-08-2014 05:53 AM
Wheels
I was wondering if the wheels have been sold yet? Please let me know , thanks.
jlwdvm 03-08-2014 09:04 AM
Does the bell housing come with a block plate? Shipping to 52722?
James OLC 03-19-2014 08:39 AM
updated
4mm 03-28-2014 10:08 AM
Can you provide pics of the sub and exhaust?
Thanks.
James OLC 03-29-2014 11:52 AM
Thanks.
Made a new post to accommodate all of the pictures - you will find it here:
https://lateral-g.net/forums/show...d=1#post544084
