Marshall SCX Gauges & Marquez Cluster
5 Attachment(s)
Item Location (City/State): Sacramento
Price:$400.00 Description: 6 Gauge Set of Marshall SCX Gauges. Includes Speedo, Tach, Oil Press, Water Temp, Volts & Fuel Level. These LED backlit gauges are awesome. Check out the site for better pics. http://www.marshallinstruments.com/c.../scx_black.cfm Dimmer Switch for LED Gauges http://www.marshallinstruments.com/products/9235.cfm Marquez Camaro Gauge Housing with bezels I have 1 Brand New Gauge Housing with a full set of Bezels. My plans was to powder coat the cluster black and polish the bezels, possibilities are endless. I was going to intergrate this set up into my 55, but changed directions. I'm in this set up $740.00 $400 plus shipping ***** NOTE***** In order to use these gauges (or any gauge for the matter) in the Marquez cluster you have to take the bezel off of the gauges. You will see in one of the pics I already took off the bezel on the speedo for mock up. To get if off you must cut it off. I have been told that you can send the gauge back to Marshall and they will put a new bezel on it for $50.00, if you do not want to use the Marquez cluster. If you do plan on using it - then non issue. |
Bump...As well as lowered price.
:bump: for the weekend!
Another bump for the weekend...& lowered price!
Sold
