-   EFI and Forced Induction (https://www.lateral-g.net/forums/forumdisplay.php?f=47)
-   -   anyone running mega squirt? (https://www.lateral-g.net/forums/showthread.php?t=4537)
orange88 05-15-2006 05:47 AM
i have a queston. i need to know how to wire up the fan controler and also a boost controler?
Overkill 05-15-2006 05:54 AM
I run one on my Camaro, but I don't use either of those on mine (yet). Your best bet would be to post the question up on the MS forum (http://www.msefi.com/ ). They are normally pretty quick with answers.
orange88 05-15-2006 08:31 AM
ive had it up there for two day and it still going with out a reply. i thin all you do for the fan is wire up a rely with the ground to the fidle, or one of the extra open spots
Overkill 05-15-2006 01:05 PM
I'm guessing that since you want to use the boost controller function you are running the MSnS code for the processor. The boost controller function looks to be experimental at the moment, but a diagram of the circuit needed to connect it is on http://megasquirt.sourceforge.net/extra/boost.html.
It looks like you got a reply on your fan control question (http://www.msefi.com/viewtopic.php?p...control#119764.
If I get to the point of putting the turbos on my Camaro and changing the fan to be operated from MS instead of the sensor in the manifold I'll try to remember to post up what I did...
