ZR9 Camaro Dyno Break-In
The 427 / LS9 in the ZR9 made 803 HP on the Mast engine dyno, and we built the car around it. In this video, we brought the car to the chassis dyno down the street from our shop to see how everything worked in the car. We had a few glitches, including a drive-by-wire throttle limited to about 35%, but ended up putting over 620 HP to the wheels. Informative day. |
I really really enjoyed that!!! I love the blue calipers, what color is it going to be?
Glad you liked it, Paul. The car is going to be ZR1 Jetstream blue. It's going to be really sharp.
These will have black inserts when the car is completed. |
GOOD LORD!!!!!!
That is a custom powdercoat blue I take it? |
Do you plan on doing a re-dyno once car is together? |
By the way, the wideband O2 sensor interface failed on the dyno, so do not believe the air fuel numbers you see on the screen in the video. We were using the wideband in the car and it was in the high 12s under load and min 13s cruising. Those 7xx numbers look bad!
Kevin where's the build thread on this project!!!???
| All times are GMT -7. The time now is 09:47 PM. |
