377 SBC motor Long Block Street/Race, BBC blocks n parts
Item Location (City/State):Astoria,NYC
Price:3500 Description:posting this for a buddy of mine,click link below for pics. 4 bolt block standard bore, 2 pc seal, dual dipstick. Elgin 3.75stroke cast crank,balanced assembly Lightweight Speedpro pistons,lightweight pins n polished beams chevy rods SPS rod bolts 11.5 comp Elgin solid cam n lifters.530 lift, moly pushrods, Comp Cams 1.6 stainless roller rockers,roller chain Dart Pro1 heads: 200cfm 64cc milled to 61cc,angle plug 2.02,1.60 valves,screw in studs,dual springs,black hardened retainers,10 deg locks,raised guide plates,ARP head bolts 400 balancer,BBC style oil pump n pick up n hardened drive Motor has new rings,bearings,chain,gaskets,pump,cam,lifters,push rods etc On engine stand for inspection/has not been fired up NO Pan,Manifold n Valve covers If no answer: leave msg n contact #718-545-8710 ask for Spiro PS: Also have 454 030 over 2 bolt main 2 pc seal- hone n run it 400$ Bowtie block 4 bolt cast cap MarkIV 4.500 bore, short deck, no sleeves decked n O-ring 1500$ TRW Blower pistons 454 .030 over 250$ n misc BBC stuff:call with needs http://newyork.craigslist.org/que/pts/4389261670.html |
| All times are GMT -7. The time now is 01:41 AM. |
