NRG quick release steering wheel adapter
Item Location (City/State): Norcal/East Bay
Price: $100 Description: Not sure of exact model but came on my 68 Camaro with non-tilt stock column and have used 2 different Sparco wheels on it (330mm and 350mm) http://i236.photobucket.com/albums/f...psb8mvnweh.jpg http://i236.photobucket.com/albums/f...pslbgpwisy.jpg http://i236.photobucket.com/albums/f...psg9arb9tn.jpg |
NRG adapter
Interested ! Sent a PM from Pro-touring!
I've been looking for one of those, do you know if it will fit a 67 column? what is the part number? I have a Grant 3hole wheel not sure if it will bolt to that one, but I'm interested how it bolted to the spline.
I'm pretty sure that's the same one I have (the 2.5 model), and that it required an adapter to the GM column. There is a 1.5" thick adapter which bolts to the column using the stock splined shaft and nut, then you use the 6 bolt holes to attach the quick release.
I really like mine... |
I believe Bryan is right. This came on my car when I bought it so no paperwork or part number but it does look like the 2.5 model in the pics.
Does it include everything you need to bolt it to the spline like the 1.5 inch adaptor Bryon was talking about?
Flash,
Did you get my PM from Pro Touring ? You can PM me from either one. BB |
sold
| All times are GMT -7. The time now is 08:30 AM. |
