-   -   changing from points to electronic (https://www.lateral-g.net/forums/showthread.php?t=46060)
dennism 05-03-2014 11:09 AM
Question for ya'll...I have two wires going to the existing coil, but no resistor as far as I can tell. When I change to the new coil, do both those wires connect to the positive terminal?
camcojb 05-03-2014 01:34 PM
Where do these wires go now? Should be one on the negative and one (or more) on the positive.
TheJDMan 05-04-2014 06:29 PM
You need to provide more information, what specifically are you installing? I assume instructions were included with the product you purchased, you might consider reading them.
Leadfoot1 05-06-2014 06:09 PM
Originally Posted by TheJDMan (Post 548945)
You might consider reading them.
Lol!!!
Lead.
dennism 05-08-2014 10:59 AM
Thanks, I wasn't totally clear on this. There are two wires to the POSITIVE terminal, and I'm wondering if one is a resistor. I don't have an ohmmeter to check on them, and I've read the instructions carefully, but I'm confused by the section on the gap. How is that measured?
camcojb 05-08-2014 12:01 PM
You need to borrow a voltmeter and check the voltage coming in, key on. I don't know what electronic system you're converting to, some require the lower voltage of a point system, and even include a ballast to use; others require a full 12 volts to operate properly.
To answer your gap question I'd need to know what system you're using.
