| Sparks67 |
05-24-2014 02:21 PM |
If your quarters are questionable, the remove them first. Rust typically hides behind the quarters and in the structure of your car. On mine, we removed the quarters first and I had bought new NOS quarters, outer tubs, mini tubs,etc. You could blast it first, then remove the quarters and find more rust. We stripped the car and then removed the rust in those areas. Mini tub was done at the time of replacing the quarters. How to get into the nook. And crevices of the car? Well, the best way is to use some modified air tools I had this small Dotco right angle grinder with 1/4" collet. My friend had other air tools that I used, but that cleaned. the metal the best. If you blast, then it will get stuck in your car. Oh, you need to use plenty of safety equipment,with grinder.
Jeff
