-   Interior and Electrical (https://www.lateral-g.net/forums/forumdisplay.php?f=40)
-   -   GPS speedo retrofit to older speedo face? (https://www.lateral-g.net/forums/showthread.php?t=47257)
samckitt 08-21-2014 08:11 AM
Anyone done it? What speedometer did you use to get the parts from?
dontlifttoshift 08-21-2014 08:19 AM
You can use any aftermarket electric speedo (or just the guts) and then drive it with a GPS unit from Classic Instruments or Autometer.
Why? It's added cost and complexity for zero gain in functionality.
What's wrong with the VSS from your T56?
samckitt 08-21-2014 10:30 AM
Was thinking it might be easier than getting the mechanical speedo to work, & if I change gears/tires then have to recalibrate/reprogram. If its GPS, none of tthat is needed.
Sieg 08-21-2014 10:37 AM
VVS, besides GPS doesn't always have a signal.
It's plug and play and calibration is a simple procedure.
samckitt 08-21-2014 11:05 AM
VVS? What's that? You mean VSS?
I still have to do something witht he speedometer because now it is mechanically driven. And I don't want to do one of those hokey Abbot boxes, that takes the electronic signal & outputs it as mechanical to drive the speedo. I would rather convert mine to electronic. Need to find an electronic head that is compact that will work.
Sieg 08-21-2014 11:22 AM
I still have to do something with the speedometer because now it is mechanically driven. And I don't want to do one of those hokey Abbot boxes, that takes the electronic signal & outputs it as mechanical to drive the speedo. I would rather convert mine to electronic. Need to find an electronic head that is compact that will work.
Yes VSS (typo)
Call Hurst Drivelines
SSLance 08-21-2014 11:49 AM
For just a few dollars more you can get the whole Dakota Digital Dash which is basically plug n play and gives you today's electronic gauges for everything while retaining that stockish look.
Have you seen the pictures of the new colors, black face, white numbers, and red needles... They look fantastic!
dontlifttoshift 08-21-2014 12:32 PM
^^^That.
Plug in module hooks up to OBDII port. No extra sending units needed.
130fe 08-21-2014 09:05 PM
I have the VHX and they are nice. With the BIM module, all I had to do was run wires from the PCM for VSS, check eng light and oil pressure. Very easy to do!
BonzoHansen 08-22-2014 08:50 PM
My gps speedo never loses signal except maybe very briefly under wide overpasses and such. Certainly nothing bothersome.
