-   Interior and Electrical (https://www.lateral-g.net/forums/forumdisplay.php?f=40)
-   -   67 camaro anvil auto carbon center dash panel (https://www.lateral-g.net/forums/showthread.php?t=47395)
mouthster 09-02-2014 06:24 PM
1 Attachment(s)
Here is my 67 with anvil auto center dash panel. I really like the look vs the original look.
Spiffav8 09-02-2014 07:14 PM
Looks sharp!!
rickpaw 09-03-2014 06:00 AM
Originally Posted by Spiffav8 (Post 568508)
Looks sharp!!
x2. I'm doing a similar layout with a stock looking panel.
mouthster 09-03-2014 06:09 AM
The hardest part is installing it. The panel from anvil is completely flat on the back.
rickpaw 09-05-2014 04:01 AM
Ah, that explains the screws below the AC controls. My repo panel is also flat, but it's pot metal, so can be bent slightly into shape.
jwcarguy 09-05-2014 06:21 AM
That is a shame that you had to use screws through the face of a great looking panel like that!
You would think that for the money you spent on it, it would have a proper way of mounting it and the necessary hardware
That is the main reason I stuck with my stock panel and modified it to work for my application
Jeff
mouthster 09-05-2014 07:16 AM
It is a little disappointing, but they would probably give the standard answer that all cars in the 60's are slightly different and fit can not be perfect. Then they tell you to epoxy mounting hardware on yourself and that it is really easy to do. I used fancy arp stainless steel 12 point bolts and it looks better than I thought it would, also makes it easy to get on and off quickly. In the blank spot I am mounting my iPad mini similar to the goodguys g/rs camaro.
