BMR Suspension Releases New Product - Rear Suspension Kits For Early GM A-body
BMR Suspension Rear Suspension Kit for 1964-1967 GM A-Body Vehicles Launch harder, reduce wheel hop, and add cornering consistency on your 1964-1967 GM A-body with a Rear Suspension Kit from BMR Suspension. Manufactured from 1-1/2” and 1-5/8” DOM tubing, this kit includes upper control arms, lower control arms, and control arm reinforcement braces. The BMR Rear Suspension Kit (RSK007) uses greasable, 95-durometer, internally-fluted polyurethane bushings, which add a more responsive feel over the factory rubber bushings. Designed to work well for street performance, drag race, and handling applications. The heavy-duty construction of the upper and lower control arms eliminate flex, giving you much improved repeatability on the street, starting line, or in the corners. This kit is the perfect upgrade for the enthusiast looking to improve performance, while maintaining acceptable NVH and ride quality. Installation time is 3-4 hours. Available in black hammertone or red powerdercoat. Proudly made in the U.S.A.! To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055. http://i1309.photobucket.com/albums/...ps60b71247.jpg |
Friday Countdown!
| All times are GMT -7. The time now is 03:54 PM. |
