stack injection efi conversion
ive been wanting to do something "interesting" with my big blocks induction for awhile and i think ive narrowed it down. a friend of mine has a crower stack injection manifold that i can get a good deal on.
with that being said, im only gunna do it if i can convert it to efi. i know hilborn and others make efi ready setups, but i think i can be a little more budget friendly this way. basically what im looking for, is what do i need to convert it? i understand fuel rails, injectors and ecu, but what sensors and how do i do it? or are there capable companies that can do it for me? any help is very appreciated, thank you. |
1 Attachment(s)
I'm doing a stack set up on my build. I've talked to a few different sources and I've settled on Autotrend for the updates to my system based on some conversations with them and others recommendations.
http://www.autotrendefi.com/index.html |
You will need all the same sensors as in "normal" efi set up.
Fuel rails, injector and so on depends what kind of 8-stack set up you pick. We finished one just last winter, stroked big block (+600cid) with custom, hand build 8-stack Motec efi. I made a one-off 4" cowl hood that housed about 15gal plenium and air cleaner system. Just clened my phones from pics, but you can check my company FB-page, there you can see my work. 8-stack is not ideal for street use. Our set up uses large, over 2" butterflyes and sence its a big motor its little "aggressive" to drive. Difficult to go over 2800rpm with out wheel spin and cloud of smoke.. When its on, its gone.. ;) |
| All times are GMT -7. The time now is 11:31 AM. |
