-   -   Ideal hp (https://www.lateral-g.net/forums/showthread.php?t=47931)
ONEBAD78TA 10-25-2014 06:23 AM
Ideal hp
Is there an ideal amount of power to go for when building a pro tour/ track car,,,I for one have a hard time saying too much power LOL,,,I'm going to be running a 501 Cubic inch Pontiac making approx 700 hp/665 fp torque,,,I'm thinking it will be tons of fun ,,,don't think it will get a lot of traction but that's ok.
Rick D 10-25-2014 06:36 AM
I look at it a little differently, yes never TOOOO much HP!! But its when the power comes in, anyone can have a high number but is it useable power??
Intended use of the car, track, autocross, mostly stop light to stop light?? I would look at those things first then talk to your engine builder about intened use of the car?
Che70velle 10-25-2014 07:11 AM
I personally don't get real excited over peak HP numbers. I look at torque. Torque is the usable portion of the spectrum for 95% of most people on here, because most people on here aren't racing their cars, and having to wind their engines up to 7K. For me there's nothing more exciting than riding in a car, or driving one for that matter, that produces ridiculous torque numbers (down low in the powerband) and being able to lug the car around, and when you want to go, you don't have to downshift into 3rd and wind it up to pass someone, or make it up the mountain. That's what makes a good street car fun to drive. You should have plenty of fun with those numbers you mentioned, and pontiacs were always known to be torque monsters anyway. I've got 500 horses and 500ish torque, and that will be plenty for my street car. Now if I were 25 years old, I'd refuse to believe what I've just written, because more is better, right?
WSSix 10-25-2014 06:19 PM
My preferences are along the line with Scott's. It's the reason I ultimately decided to build a 383. It won't make much if any more horse power than a 355, but it will bring the torque in hard a lot sooner. I also am only a street car. For street cars, the most fun I have had is when they are making 400-450 at the wheels with broad torque bands.
Flash68 10-25-2014 07:33 PM
Yep, broad torque band.... that's what I would want.
So about the car... what are we talking about for suspension, tires, track width, weight etc?
Vegas69 10-25-2014 07:53 PM
Can you drive? ha
mach1stang 10-25-2014 08:15 PM
I prefer a lighter car with a real lightweight drivetrain and a mild amount of power to a crazy amount of power. Much rather use every last HP and TQ I have then waste half of it spinning the tires.
Sieg 10-25-2014 09:08 PM
You can definitely hook those hp/tq specs up with a properly set up chassis and right tire combo.
Hp/tq to weight ratio is more important than the hp & tq pinnacles.
ONEBAD78TA 10-26-2014 01:47 PM
I agree guys torque is the most fun,,,the car has an art morrison 4link with 335 bfgoodrich r1 for tread on the rear ,,and its going to have an extended travel coil over setup with eibach 600 pound springs and viking shocks,willwood 14 in brakes ,front and 13 in in rear.,,it should have tons of torque starting really low in the rpms and good through about 5k,,,but the dyno run hasnt been done yet I will post up the actuall numbers when i get them,,not sure on what the car weighs,,but its alot lighter than stock im sure but with the full cage thats been installed its probably put on a few lbs..
carbuff 10-26-2014 02:00 PM
Says the guy who is building the 8500-9000 rpm NASCAR motor. ;)
