First Day sale: RainGear Hidden Wiper motor system - FREE Intermittent switch upgrade
The first offer we have for you is the red hot RainGear Hidden Windshield wiper motor / Linkage system. These kits fully replace your motor, linkage and wiring with all brand new parts but use the stock wiper arms/blades yet cost less than firewall mounted motor kits and the end result here is a FULLY smooth firewall!
Many of you have seen the Intro special Ad we ran here for these kits. We saw huge success with these kit's and wanted to bring them back, but this time with the option of a FREE upgrade to the Delay swipe option vs the standard 2 speed system. We are already offering incredible prices on these kits and the Intermittent option normally adds between $45-75 depending on the application Most muscle car applications will install in the cowl area, where your existing wiper linkage is, other cars with no room in this area like the 55-57 Bel Air will install under the dash. If you follow this link to the install instructions, click your car and you can see where it will install, with pics in most applications: http://www.pacificwesterndesign.com/documents.htm If you want a PROVEN USA MADE system that will allow you to COMPLETELY smooth your firewall and not worry about the ugly wiper motor hanging off there this is THE answer! Its also a great choice for those doing a build that are missing the stock wiper transmission parts and/or motor.. Applications use the stock Arms/Blades and are Available in the regular 2 speed system CARS:53 - 54 Chevy 55 - 57 Chevy 53 - 62 Corvette 67 - 69 Camaro / Firebird (NEW) 68 - 74 Nova / X - Body 64 - 67 Chevelle / A-Body TRUCKS: 47 - 54 Chevy / GMC 55 - 59 Chevy / GMC 48 - 52 F-1 Ford 53 - 55 F-100 Ford 56 F-100 Ford The RainGear wiper system is a rugged, time tested and proven, lever and link windshield wiper system. It is specifically designed to completely replace the original factory wiper system. Because RainGear systems fits entirely inside the wiper cowl where the your current linkage is in most muscle car applications (Camaro, Firebird, Chevelle, Nova) or under the dash (55-57 Chevy car, ect) you can remove the old firewall mounted motor entirely. This will free up engine compartment room for that big block motor or give more clearance for an HEI distributor. Or you can leave the old wiper motor in for authenticity. The exterior uses the original arms, blades and trim. Both the standard and intermittent switches can use the original knob and information bezel, again retaining perfect authenticity. In fact, no one will know you have the RainGear system installed, except that when it rains others will be struggling to see out their windshield while you will clearly see the road ahead. Specifications: 12 volt, 5 amp, 2 speed electric motor. Heavy duty brackets, links and wiper towers. Weather-sealed electrical parts. No drilling! Uses stock mounting points. Uses original arms, blades, trim, knob and bezel. Optional intermittent switch. Optional washer unit. Fully guaranteed. Includes comprehensive, illustrated installation instructions. Made in the USA Install is very straight forward and requires no special skills at all and can be done in just an afternoon! |
| All times are GMT -7. The time now is 05:29 AM. |
