NEW! 69 Camaro Stamped Steel Gas Tank with Notched corners + Powder Coated! Mini-Tub
This is a brand new offering in the market! Perfect for those who don't want/need a Vaporworx Stainless setup.
Clear your Mini-Tubs and 3" Exhaust! Please, don't mistake these as "close" to a Vaporworx setup, they are NOT, this is a stamped steel tank, built to accept an electric fuel pump and sending unit. Of course, there is a LARGE price difference, we are able to offer these with a Walbro Pump, Sending unit, Straps, Anti-Squeak and a Cap UNDER $600 FREE shipped in the 48 states! (Please PM or Call and let us know what motor/HP you are running so we can give you an accurate price as the pumps do vary in $) This is a good tank, it will do the job just fine and we are able to ship it with one of several different Liter Per Hour Walbro USA made electric IN TANK fuel pumps depending on your fuel needs, a sending unit, straps, Anti-Squeak strap liners and a cap! The Vitals: This notched corner 69 Camaro and Firebird tank is perfect for mini-tub applications. The front of this tank is narrowed to 27" to clear up to a 345 tire and 3" exhaust. To help regain fuel capacity from the notched corners this tank is 1" deeper than stock. Even if you do not have a mini-tubbed car this tank will work on a stock car where you need a little more clearance for exhaust. Please note that this tank will not work with narrowed leaf spring kits. - 1969 Chevy Camaro and Pontiac Firebird EFI Fuel Tank - Fuel Injection Ready! - Uses our GPA series fuel pumps, available in 5 sizes. - Uses aftermarket 5-bolt senders. Multiple Ohm ranges available to work with factory or aftermarket gauges. - EFI style internal baffling. Extra Large 4.3 liter internal fuel tray to prevent fuel pump starvation. - Perfect for your Pro-Touring, Autocross or Road Racing Ride - Fuel pump and sender are recessed in the tank for easy installation with no modification needed to your car. - Looks like an OE tank when installed. - Coated galvanized steel then Powder Coated Silver. - 1" Deeper than stock - Longer mounting straps included with the tank - Size is: 39-3/8" x 20-7/8" x 8-3/4" http://www.tanksinc.com/cartimages/prd_458.jpg http://www.tanksinc.com/cartimages/prod_ssh_520_170.jpg http://www.tanksinc.com/cartimages/prod_ssh_520_171.jpg http://www.tanksinc.com/cartimages/prod_ssh_520_172.jpg http://www.tanksinc.com/cartimages/prd_lg_227.jpg |
The 67-68 tank is also available, in stock, ready to ship!
http://www.tanksinc.com/cartimages/prd_457.jpg |
| All times are GMT -7. The time now is 10:16 AM. |
