10mm door gap
I have a door gap 10mm at the bottom of the door to the rocker this is after installing new quarters , is there a go to method to fix, welding a 6mm rod to the door? or sum other thanks Darrin
A lot of people weld TIG rod onto the edge, then grind until it matches the curve.
| All times are GMT -7. The time now is 10:44 AM. |
