LS3 Polished Holley High Ram Manifold, 102mm Throttle Body, 42# Injectors Price drop!
Item Location (City/State):Las Vegas, NV
Price:100 Description: I am posting this for a friend, please contact Jason direct This is a LS3 Holley High Ram, that has been polished also have a 102mm throttle body if someone needs one, have fuel lines/ crossover , fittings ***Wtt Trade For Fast 102mm Need A Fast Intake (this will not fit with my MSD atomic fuel injection so I am looking for a fast for trade) Sold!!Holley high Ram -$100 102mm with Adjustable TPS for the perfect tip-in, Custom built CNC 4130 Chromoly throttle blade, for High Boost, -$175 Set of (-8-) Fast Green top 42lbs Injectors at 43.5-psi or 49lbs at 60-psi in Las Vegas, NV call/ text Jason (702)327-9907 email [email protected] |
I want this so bad and it's a great price but won't fit under my hood:getout:
Yes it is pretty, my buddy spent a good dollar having it all polished He is upset that he can't use it now Jeff |
Would the height be similar to a truck intake?
Base Plenum Top Mounting Flange Height 8.42 to the lifter valley cover flange on engine block. Total Height with 92/102mm EFI Plenum Top 12.32 to the lifter valley cover flange on engine block. Port Size 2.49 Height x 1.21 Wide Mounting Flange Gasket Type Standard LS3 Molded O-Ring Plenum Top Gasket Type 3/32 Round O-ring Cord Throttle Body Flange Location, with 92/102mm EFI Plenum Top : Height 8.42 (from engine block lifter valley cover flange), Longitudinal Location 3.84 (forward from engine block front flange), Angle 25 deg. (down from vertical) Runner Length 6.50, As-Cast Runner Cross-Sectional Area Tapered 4.25 in² to 2.77 |
price drop!
| All times are GMT -7. The time now is 05:23 AM. |
