Firebird Frame Rail Dilemma
Hello all, I am working on a 71 Firebird. The rear frame rails are shot and need replaced. I ordered s set and found out they were not full length. I couldn't find a full length set so I ordered a set of competition engineering rails because I am going the pro touring route and figured these would stiffen things up a bit. Really not sure if that was a good idea or not. I also got the frame connectors but I am wondering if the Detroit Speed connectors might work better. Anyone out there have any advice? I also am in search of someone to install said rails as my guy is too backed up to install them anytime soon.:drowninga:
Thanks Don. That gives me a glimmer of hope.
Also check with Autoweld in Pennsylvania.
They make very nice frame rails and a version that hugs the trunk closer for more tire room. A bit more money but a quality piece. http://autoweldchassis.com/spec.ivnu scroll down about a 3rd of the way down. The DSE subframe connectors are the way to go if you like a clear under carrige. |
You might give Mike Dusold at Dusold Designs a call as he just replaced the frame rails on a 73 TA. That was partially covered here as 73 Klrbrd.
| All times are GMT -7. The time now is 11:36 AM. |
