Vintage Air (compressor) mounting brkt. opinions wanted.
Good afternoon all, I am looking for opinions on the after market A/C compressor mounting brackets for an LS-1 engine. The Vintage Air (Sanden 508) compressor mounts up high and I am aware of two mounts and I am sure there are others. What does eveyone reccomend. I know of the Holley 20-134 brkt. and that also requires a spacer # 21-2 or the Kwik Performance. The Holley is cast aluminum and looks factory, the Kwik Performance is flat stock aluminum with spacers. Should I be considering another brand, please chime in with your thoughts and experience. The rest of my pulley/drive system is factory stock 2004 GTO LS-1. Thank You.
Tim john--- |
don't use the kwik, they have a tendency to squeal because they don't line up perfectly. I prefer the holley bracket for use with factory brackets.
Another vote for the Holley AC bracket. I am using it with the stock corvette serp setup and it works great and looks like it is factory.
I have the Holley bracket and it looks great, but mine squeaks. Everything is brand new and I have tried multiple belts, tensioners and idlers to no avail.
Andrew |
I used the Kwik on My LS7 build and Holley on my the last LS3 I did and am using the holley on my new build.
Another Vote for Holley btw I used the entire Holley Front Drive from Jegs on my current build. |
Thank You everyone for chiming in, when I order my Vintage Air unit I will be ordering the Holley set up. This forum is a great resource for real world applications. Thanks so much.
Tim john--- |
| All times are GMT -7. The time now is 10:05 AM. |
