-   EFI and Forced Induction (https://www.lateral-g.net/forums/forumdisplay.php?f=47)
-   -   Vaporworxs Tank (https://www.lateral-g.net/forums/showthread.php?t=50822)
DKz Garage 08-05-2015 02:26 PM
Vaporworxs Tank
I have a Rick's Vaporworx with the 5th gen Camaro GM fuel pump w/internal pressure reg:I am trying to calibrate my Dakota Digital fuel gauge...does anyone know the ohms on the sending unit that Ricks uses?
Nobody at Ricks could give me a "for sure" answer.
Thanks!
Mkelcy 08-05-2015 03:16 PM
I'm not sure this is what you're asking, but the range of sender that's part of the Gen 5 in-tank pump is 33-240 ohms.
DKz Garage 08-05-2015 05:24 PM
Thanks. I edited my post. I am looking for the ohms on the sending unit
Mkelcy 08-05-2015 08:03 PM
Which I provided.
130fe 08-06-2015 05:35 AM
yeah, depends. Are you using the 5th gen fuel sensor (part of the fuel pump assembly) or one mounted separately? I know Carl C posted some info on how to integrate the 5th gen sender. My vaporworx tank uses one of the separately mounted 0/90 tube senders. Mike is correct about the 5th gen sender specs.
DKz Garage 08-06-2015 06:28 AM
Originally Posted by Mkelcy (Post 613126)
Which I provided.
Thanks Mike....
How can you tell which sending unit you have?....I put the tank in and it's hard to see above the tank at this point. It seemed to me the sending unit was separate from the fuel pump...I suppose I could try the two different ohm settings on the Dakota digital and see which one works?? 0-90 and then 33-240. I know there is only about a gallon of fuel in the tank at this point.
CarlC 08-06-2015 04:25 PM
Can you please post a photo of the top of the tank?
130fe 08-07-2015 04:01 AM
My tank looks like this one-
http://s1134.photobucket.com/user/67...2c4c6.jpg.html
The sender is seperate from the fuel bucket assembly (has black and white wires).
Musclerodz 08-07-2015 12:48 PM
They don't use the sender internal to the pump, they use a seperate sender, should be 0-90 ohm
DKz Garage 08-07-2015 12:57 PM
I tried several of the preset senders in my Dakota Digital menu, including the 0-90ohm...with a know half tank of gas, it read as full?? I tried the "VDO" setting and it seems fairly accurate.... Not sure what to think other than this must be the correct choice.
Thanks for the input!
